メインコンテンツにスキップ
Hover-1 Titan Right Gyroscope Replacement
必要な工具と部品
  1. Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: 手順 1、 2の画像 1 Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: 手順 1、 2の画像 2
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Right Gyroscope Replacement: 手順 2、 2の画像 1 Hover-1 Titan Right Gyroscope Replacement: 手順 2、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Right Gyroscope Replacement: 手順 3、 3の画像 1 Hover-1 Titan Right Gyroscope Replacement: 手順 3、 3の画像 2 Hover-1 Titan Right Gyroscope Replacement: 手順 3、 3の画像 3
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: 手順 4、 2の画像 1 Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: 手順 4、 2の画像 2
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Right Gyroscope Replacement: 手順 5、 3の画像 1 Hover-1 Titan Right Gyroscope Replacement: 手順 5、 3の画像 2 Hover-1 Titan Right Gyroscope Replacement: 手順 5、 3の画像 3
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  6. Hover-1 Titan Right Gyroscope Replacement: 手順 6、 2の画像 1 Hover-1 Titan Right Gyroscope Replacement: 手順 6、 2の画像 2
    • Unplug the bottom left connector by squeezing it and pulling it away from the board.
  7. Hover-1 Titan Right Gyroscope Replacement: 手順 7、 2の画像 1 Hover-1 Titan Right Gyroscope Replacement: 手順 7、 2の画像 2
    • Unplug the white wires by squeezing the connector and pulling away from the board.
  8. Hover-1 Titan Right Gyroscope Replacement: 手順 8、 2の画像 1 Hover-1 Titan Right Gyroscope Replacement: 手順 8、 2の画像 2
    • Unplug one set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  9. Hover-1 Titan Right Gyroscope Replacement: 手順 9、 2の画像 1 Hover-1 Titan Right Gyroscope Replacement: 手順 9、 2の画像 2
    • Unplug the other set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  10. Hover-1 Titan Right Gyroscope Replacement: 手順 10、 1の画像 1
    • Cut the cable tie and unplug the remaining wires.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jessica Ouyang
メンバー登録日: 10/08/18
619 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018人のメンバー
CPSU-WHITE-F18S15G4
4 メンバー
10のガイドは作成済み
コメント 1 件
Where can I get the circuit boards for the left and right ?
jfsucher - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 39
今までの合計 1,083
