メインコンテンツにスキップ
Hover-1 Titan Power Button Replacement
必要な工具と部品
  1. Hover-1 Titan Power Button Replacement, Bottom Right Panel: 手順 1、 2の画像 1 Hover-1 Titan Power Button Replacement, Bottom Right Panel: 手順 1、 2の画像 2
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Power Button Replacement: 手順 2、 2の画像 1 Hover-1 Titan Power Button Replacement: 手順 2、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Power Button Replacement: 手順 3、 3の画像 1 Hover-1 Titan Power Button Replacement: 手順 3、 3の画像 2 Hover-1 Titan Power Button Replacement: 手順 3、 3の画像 3
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Power Button Replacement, Power Button: 手順 4、 2の画像 1 Hover-1 Titan Power Button Replacement, Power Button: 手順 4、 2の画像 2
    • Disconnect the battery by holding the yellow connectors and pulling apart.
  5. Hover-1 Titan Power Button Replacement: 手順 5、 3の画像 1 Hover-1 Titan Power Button Replacement: 手順 5、 3の画像 2 Hover-1 Titan Power Button Replacement: 手順 5、 3の画像 3
    • Unplug the red and black power button connector on the motherboard by squeezing the connector and pulling away from the board.
    • You can also unplug the light connector to free up your work space.
  6. Hover-1 Titan Power Button Replacement: 手順 6、 2の画像 1 Hover-1 Titan Power Button Replacement: 手順 6、 2の画像 2
    • Use an adjustable wrench to remove the 14 mm nut holding the button in the shell.
  7. Hover-1 Titan Power Button Replacement: 手順 7、 3の画像 1 Hover-1 Titan Power Button Replacement: 手順 7、 3の画像 2 Hover-1 Titan Power Button Replacement: 手順 7、 3の画像 3
    • Pull the power button out of the panel.
    • Replace the power button.
終わりに
作成者
4人の作成者と共同で作成されました。
Alexander Pham
メンバー登録日: 10/07/18
221 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018人のメンバー
CPSU-WHITE-F18S15G4
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 19
今までの合計 535
