メインコンテンツにスキップ
Hover-1 Titan Left Gyroscope Replacement
必要な工具と部品
  1. Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: 手順 1、 2の画像 1 Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: 手順 1、 2の画像 2
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Hover-1 Titan Left Gyroscope Replacement: 手順 2、 2の画像 1 Hover-1 Titan Left Gyroscope Replacement: 手順 2、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Left Gyroscope Replacement: 手順 3、 3の画像 1 Hover-1 Titan Left Gyroscope Replacement: 手順 3、 3の画像 2 Hover-1 Titan Left Gyroscope Replacement: 手順 3、 3の画像 3
    • Grip the bottom left panel and lift up to remove.
  4. Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: 手順 4、 2の画像 1 Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: 手順 4、 2の画像 2
    • Unplug the battery from the gyroscope by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Left Gyroscope Replacement: 手順 5、 3の画像 1 Hover-1 Titan Left Gyroscope Replacement: 手順 5、 3の画像 2 Hover-1 Titan Left Gyroscope Replacement: 手順 5、 3の画像 3
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  6. Hover-1 Titan Left Gyroscope Replacement: 手順 6、 2の画像 1 Hover-1 Titan Left Gyroscope Replacement: 手順 6、 2の画像 2
    • Unplug the bottom right connector by squeezing it and pulling it away from the board.
  7. Hover-1 Titan Left Gyroscope Replacement: 手順 7、 2の画像 1 Hover-1 Titan Left Gyroscope Replacement: 手順 7、 2の画像 2
    • Unplug the light connector by squeezing it and pulling away from the board.
  8. Hover-1 Titan Left Gyroscope Replacement: 手順 8、 2の画像 1 Hover-1 Titan Left Gyroscope Replacement: 手順 8、 2の画像 2
    • Unplug the blue and white wires by squeezing the connector and pulling away from the board.
  9. Hover-1 Titan Left Gyroscope Replacement: 手順 9、 2の画像 1 Hover-1 Titan Left Gyroscope Replacement: 手順 9、 2の画像 2
    • Unplug the small white connector by squeezing it and pulling away from the board.
  10. Hover-1 Titan Left Gyroscope Replacement: 手順 10、 2の画像 1 Hover-1 Titan Left Gyroscope Replacement: 手順 10、 2の画像 2
    • Unplug the plug in the red connector.
    • The red plug is glued to the board, so this step will require extra force.
  11. Hover-1 Titan Left Gyroscope Replacement: 手順 11、 2の画像 1 Hover-1 Titan Left Gyroscope Replacement: 手順 11、 2の画像 2
    • Unplug the charging cable connector by squeezing it and pulling it away from the board.
  12. Hover-1 Titan Left Gyroscope Replacement: 手順 12、 1の画像 1
    • Cut the cable tie.
    • Unplug the remaining wires.
    • The connectors for the remaining wires are in the rubber covers.
終わりに
作成者
4人の作成者と共同で作成されました。
Jessica Ouyang
メンバー登録日: 10/08/18
619 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018人のメンバー
CPSU-WHITE-F18S15G4
4 メンバー
10のガイドは作成済み
2 件のコメント
I’ve got an active broken on the cover not the one to to speaker the other one. Does anyone know where is terminates. I can’t see where it came from. It can only reach the circuit board or the active of the speaker.
Mark - 返信
Where do you buy the board?
eden11 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 15
今までの合計 995
