メインコンテンツにスキップ
Hover-1 Titan Charge Port Replacement
必要な工具と部品
  1. Hover-1 Titan Charge Port Replacement, Bottom Left Panel: 手順 1、 2の画像 1 Hover-1 Titan Charge Port Replacement, Bottom Left Panel: 手順 1、 2の画像 2
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Hover-1 Titan Charge Port Replacement: 手順 2、 2の画像 1 Hover-1 Titan Charge Port Replacement: 手順 2、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Charge Port Replacement: 手順 3、 3の画像 1 Hover-1 Titan Charge Port Replacement: 手順 3、 3の画像 2 Hover-1 Titan Charge Port Replacement: 手順 3、 3の画像 3
    • Grip the bottom left panel and lift up to remove.
  4. Hover-1 Titan Charge Port Replacement, Charge Port: 手順 4、 3の画像 1 Hover-1 Titan Charge Port Replacement, Charge Port: 手順 4、 3の画像 2 Hover-1 Titan Charge Port Replacement, Charge Port: 手順 4、 3の画像 3
    • Unplug the red and black charge port wire from the motherboard by squeezing the connector located at the top right of the motherboard and pulling the connector away from the board.
  5. Hover-1 Titan Charge Port Replacement: 手順 5、 3の画像 1 Hover-1 Titan Charge Port Replacement: 手順 5、 3の画像 2 Hover-1 Titan Charge Port Replacement: 手順 5、 3の画像 3
    • Use an adjustable wrench to loosen the 14 mm nut and lift it off the charge port.
  6. Hover-1 Titan Charge Port Replacement: 手順 6、 2の画像 1 Hover-1 Titan Charge Port Replacement: 手順 6、 2の画像 2
    • Remove the old charge port by pulling the wires all the way through the panel.
    • Replace the old charge port with the new charge port.
終わりに
作成者
4人の作成者と共同で作成されました。
Jessica Ouyang
メンバー登録日: 10/08/18
619 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018人のメンバー
CPSU-WHITE-F18S15G4
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 24
今までの合計 657
