メインコンテンツにスキップ
Hover-1 Nomad Power Button Replacement
必要な工具と部品
  1. Hover-1 Nomad Power Button Replacement, Outer Shell: 手順 1、 3の画像 1 Hover-1 Nomad Power Button Replacement, Outer Shell: 手順 1、 3の画像 2 Hover-1 Nomad Power Button Replacement, Outer Shell: 手順 1、 3の画像 3
    • Break the two warranty stickers by poking a screwdriver through them or peeling them off.
    • Remove the following twenty screws by rotating the screwdriver counterclockwise:
    • Eight 16.2mm Phillips #2 screws
    • Eight 15mm Phillips #2 screws
    • Four 19.1mm Phillips #2 screws
    • The holes containing most of the screws are deep and narrow. A screwdriver with interchangable bits will not be able to reach them.
    • Do not over-tighten the screws during reassembly. Over-tightened screws can crack the plastic channels holding the shell to the frame of the hoverboard.
  2. Hover-1 Nomad Power Button Replacement: 手順 2、 3の画像 1 Hover-1 Nomad Power Button Replacement: 手順 2、 3の画像 2 Hover-1 Nomad Power Button Replacement: 手順 2、 3の画像 3
    • Use a nylon spudger to pry the metal handle away from the outer shell.
    • Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
    • Lift the hoverboard off the metal handle.
    • Repeat for the handle on the other side of the hoverboard.
  3. Hover-1 Nomad Power Button Replacement: 手順 3、 1の画像 1
    • Lift the plastic cover on each side up and away from the device.
    • Multiple wires connect the circuit boards to the outer shell. Remove the shell gently to avoid damaging the wires or components.
  4. Hover-1 Nomad Power Button Replacement: 手順 4、 2の画像 1 Hover-1 Nomad Power Button Replacement: 手順 4、 2の画像 2
    • Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
    • Charging port wires
    • Speaker assembly wires
    • Power button wires
    • Headlight wires
    • Only the headlight wires need to be disconnected from the other circuit board.
    • Ensure the wires are connected to the correct ports on the circuit board during reassembly.
  5. Hover-1 Nomad Power Button Replacement, Power Button: 手順 5、 2の画像 1 Hover-1 Nomad Power Button Replacement, Power Button: 手順 5、 2の画像 2
    • Peel off the glue around the power button.
    • Unscrew the hexagonal nut around the power button by rotating the nut counterclockwise with a pair of pliers.
  6. Hover-1 Nomad Power Button Replacement: 手順 6、 1の画像 1
    • Feed the wire and connector through the removed nut and pull the power button out through the hole in the outer casing.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Samuel Frazee
メンバー登録日: 10/08/18
1,015 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team S15-G1, White Fall 2018 Cal Poly, Team S15-G1, White Fall 2018人のメンバー
CPSU-WHITE-F18S15G1
4 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 12
今までの合計 420
