はじめに
If the hoverboard is unwilling to move and it is fully charged, there may be an issue with the wheel motors.
パーツ
パーツは指定されていません。
Flip the hoverboard over so the labels are facing upwards.
Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
Place the hoverboard so the four 36mm Allen bolts are pointing up.
Remove the four 36mm Allen bolts on each side using a 5mm Allen Wrench.
ある他の人がこのガイドを完成しました。
