はじめに
If your hoverboard is experiencing issues where it will not move forward or unable to maintain balance, there is a problem with the gyroscope controlling the wheels.
  1. Flip the hoverboard over so the labels are facing upwards.
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Remove the bottom cover by lifting it away from the hoverboard.
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
    • Place the hoverboard so the sensor boards face you.
    • Remove battery connector by pulling it apart.
    • Slide the rubber sheaths away from the connector on the blue, green, and yellow wires.
    • Disconnect the colored wires by pulling them apart.
    • The large colored wires connecting the sensor boards to the wheels need to match for the motor to operate correctly.
    • Remove the white cable from the sensor boards by disconnecting the cable on each side of the hoverboard.
    • To release the cable connector, squeeze the sides while pulling it away from the sensor board.
    • Remove the four 10mm screws with a Phillips #1 screwdriver.
    • Remove the sensor board by lifting it away from the hoverboard.
    • Repeat steps 4-8 to remove the sensor board from the other side.
まとめ
Eduardo Miranda
メンバー登録日: 2018年10月08日
238 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S13-G2, White Fall 2018 Cal Poly, Team S13-G2, White Fall 2018人のメンバー
CPSU-WHITE-F18S13G2
3 メンバー
4のガイドは作成済み
統計データを表示:
過去 24時間: 4
過去 7 日: 28
過去 30 日: 268
今までの合計 353
