はじめに
If your hoverboard is experiencing issues where it will not move forward or unable to maintain balance, there is a problem with the gyroscope controlling the wheels.
必要な工具と部品
Flip the hoverboard over so the labels are facing upwards.
Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
Remove one connector from the non-battery side circuit board.
Remove the next connector from the non-battery side circuit board.
Place the hoverboard so the sensor boards face you.
Remove battery connector by pulling it apart.
Slide the rubber sheaths away from the connector on the blue, green, and yellow wires.
Disconnect the colored wires by pulling them apart.
Hola buenos dias, sabes que requiero las carcasas de este mismo modelo, tendrás?
6 の人々がこのガイドを完成させました。
9 件のコメント
Where can you purchase the replacement board for the Hover-1 liberty?
Make this site useful by telling us where we can buy a new circuit board.
Where do you get circuit board from.
Hello Eduardo. Please can you tell me who sells specifically this version of the controller boards ?
Hi all, do you know where I can buy a Hover-1 Rocker Gyroscope Sensor Boards?
Thanks Peter
I replaced motherboard and gyroscope still have a red light on one side green on battery side
