メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
The first step to replacing any internal component in the hoverboard is to remove the external plastic covers. You will need a Phillips #2 screwdriver with a long shaft for this guide.
パーツ
パーツは指定されていません。
  1. Flip the hoverboard over so the labels are facing upwards. Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. The Essential Toolkit
    コンパクト版iFixitキットの中で最も利便性の高いツール
    ショップを見る
    ショップを見る
  3. Remove the bottom cover by lifting it away from the hoverboard. The cover on the side without the battery has two wires connecting the power button and charging port.
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  4. Remove one connector from the non-battery side circuit board. Remove the next connector from the non-battery side circuit board. To remove the connectors, pinch the plug and pull away from the circuit board.
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
終わりに
ある他の人がこのガイドを完成しました。
Patrick Bacon
メンバー登録日: 2018年10月08日
366 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S13-G2, White Fall 2018 Cal Poly, Team S13-G2, White Fall 2018人のメンバー
CPSU-WHITE-F18S13G2
3 メンバー
4のガイドは作成済み
コメント1件
I'm gettin nothin at all.. Charger is green.. But absolutely nothing when press the on button.. All the cables are connected.. No lights or anythin.. Can anyone help.
stemirnoff@hotmail.co.uk - 返信
コメントを追加
統計データを表示:
過去 24時間: 3
過去 7 日: 26
過去 30 日: 150
今までの合計 1,762
