はじめに
If your Hover-1 Liberty is not holding a charge and there is no problem with the charging cord, then the battery needs to be replaced. In this guide, the side of the hoverboard with the words Hover-1 printed on it will be referred to as the right side.
ツール
パーツ
パーツは指定されていません。
Flip the hoverboard over so the labels are facing upwards.
Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
Disconnect the large red and black wire from the battery by pulling apart the connector.
ある他の人がこのガイドを完成しました。
