この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Is one side of the hoverboard not functioning, or unresponsive? This is a guide to show you how to replace the wheel, or motor (which is apart of the wheel) on the Hover-1 Horizon. This guide requires a Phillips #2 and a Phillips #1 screwdriver, and a 6mm hex key.
必要な工具と部品
Remove the two connectors on either side of the board by lifting the tab and pulling out.
Remove the connector in the middle of the board by squeezing the tab and pulling up.
Remove the four 30mm Hex #6 screws.
Lift away the silver bracket and set it to the side.
ある他の人がこのガイドを完成しました。
