メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Does your Hover-1 Horizon not turn off? This is a guide to show you how to replace the power button, the most likely cause of your issue. This guide requires a Phillips #2 and a Phillips #1 screwdriver.
パーツ
パーツは指定されていません。
  1. Remove the six 12mm Phillips #2 screws holding the base plate. Remove the six 12mm Phillips #2 screws holding the base plate.
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Remove the two 11mm Phillips #1 screws that hold the base plate to the body. Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  3. Remove the base plate by lifting it up. The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side. The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
  4. Reorient the Hover-1 Horizon so the base plate opens towards you.
    • Reorient the Hover-1 Horizon so the base plate opens towards you.
  5. Remove the connector by squeezing the tab and lifting up. Remove the connector by squeezing the tab and lifting up. Remove the connector by squeezing the tab and lifting up.
    • Remove the connector by squeezing the tab and lifting up.
  6. Remove the second connector by squeezing the tab and pulling up. Remove the second connector by squeezing the tab and pulling up. Remove the second connector by squeezing the tab and pulling up.
    • Remove the second connector by squeezing the tab and pulling up.
  7. Unscrew the power button by holding the front and twisting the back nut counter-clockwise. Push the power button through the base plate to remove. A hot air gun may need to be used to remove the adhesive connecting the base plate to the power button.
    • Unscrew the power button by holding the front and twisting the back nut counter-clockwise.
    • Push the power button through the base plate to remove.
    • A hot air gun may need to be used to remove the adhesive connecting the base plate to the power button.
終わりに
Christina Fong
メンバー登録日: 2018年10月08日
165 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S13-G6, White Fall 2018 Cal Poly, Team S13-G6, White Fall 2018人のメンバー
CPSU-WHITE-F18S13G6
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 158
