この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Is one side of your Hover-1 Horizon unresponsive? This is a guide to show you how to replace the left gyroscope board, the most likely culprit to your problem. This guide requires a Phillips #2 and a Phillips #1 screwdriver.
必要な工具と部品
Remove the two connectors on either side of the board by lifting the tab and pulling out.
Remove the connector in the middle of the board by squeezing the tab and pulling up.
ある他の人がこのガイドを完成しました。
