メインコンテンツにスキップ
Hover-1 Horizon Left Gyroscope Sensor Board Replacement
必要な工具と部品
  1. Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Base Plate: 手順 1、 2の画像 1 Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Base Plate: 手順 1、 2の画像 2
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 2、 2の画像 1 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 2、 2の画像 2
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  3. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 3、 3の画像 1 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 3、 3の画像 2 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 3、 3の画像 3
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
  4. Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: 手順 4、 3の画像 1 Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: 手順 4、 3の画像 2 Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: 手順 4、 3の画像 3
    • Remove the two connectors on either side of the board by lifting the tab and pulling out.
    • Remove the connector in the middle of the board by squeezing the tab and pulling up.
  5. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 5、 2の画像 1 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 5、 2の画像 2
    • Remove the four 11mm Phillips #1 screws that hold the cover on.
  6. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 6、 3の画像 1 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 6、 3の画像 2 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 6、 3の画像 3
    • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
    • Lift the board to reveal the connections on the bottom.
  7. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 7、 2の画像 1 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 7、 2の画像 2
    • Remove the middle connector by squeezing the top of the tab and pulling up.
  8. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 8、 3の画像 1 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 8、 3の画像 2 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 8、 3の画像 3
    • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
    • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
  9. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 9、 3の画像 1 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 9、 3の画像 2 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 手順 9、 3の画像 3
    • Unclip the black connector by squeezing both sides and pulling them apart.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Casey Winans
メンバー登録日: 10/08/18
324 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S13-G6, White Fall 2018 Cal Poly, Team S13-G6, White Fall 2018人のメンバー
CPSU-WHITE-F18S13G6
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 20
過去 30 日: 72
今までの合計 3,566
