メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Is your hoverboard unbalanced or leaning to one side while riding? This is a guide to show you how to remove the left balance sensor tab on the Hover-1 Horizon, the most likely culprit to your problem. This guide requires a Phillips #2 and a Phillips #1 screwdriver.
パーツ
パーツは指定されていません。
  1. Remove the six 12mm Phillips #2 screws holding the base plate. Remove the six 12mm Phillips #2 screws holding the base plate.
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Remove the two 11mm Phillips #1 screws that hold the base plate to the body. Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  3. Remove the base plate by lifting it up. The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side. The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
  4. Remove the two connectors on either side of the board by lifting the tab and pulling out. Remove the connector in the middle of the board by squeezing the tab and pulling up. Remove the connector in the middle of the board by squeezing the tab and pulling up.
    • Remove the two connectors on either side of the board by lifting the tab and pulling out.
    • Remove the connector in the middle of the board by squeezing the tab and pulling up.
  5. Remove the four 11mm Phillips #1 screws that hold the cover on. Remove the four 11mm Phillips #1 screws that hold the cover on.
    • Remove the four 11mm Phillips #1 screws that hold the cover on.
  6. Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount. Lift the board to reveal the connections on the bottom. Lift the board to reveal the connections on the bottom.
    • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
    • Lift the board to reveal the connections on the bottom.
  7. Remove the middle connector by squeezing the top of the tab and pulling up. Remove the middle connector by squeezing the top of the tab and pulling up.
    • Remove the middle connector by squeezing the top of the tab and pulling up.
  8. Remove the four 12mm Phillips #2 screws that hold the motherboard to the base. Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right . Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
    • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
    • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
  9. Unclip the black connector by squeezing both sides and pulling them apart. Unclip the black connector by squeezing both sides and pulling them apart. Unclip the black connector by squeezing both sides and pulling them apart.
    • Unclip the black connector by squeezing both sides and pulling them apart.
  10. Remove the three 10 mm Phillips #1 screws connecting the balance sensor to the hoverboard. The balance sensor tabs are made of sensitive rubber. Screw them back on slowly, and do not over-tighten. The balance sensor tabs are made of sensitive rubber. Screw them back on slowly, and do not over-tighten.
    • Remove the three 10 mm Phillips #1 screws connecting the balance sensor to the hoverboard.
    • The balance sensor tabs are made of sensitive rubber. Screw them back on slowly, and do not over-tighten.
  11. Remove the sensor tab by carefully lifting it away from the hoverboard. Remove the sensor tab by carefully lifting it away from the hoverboard.
    • Remove the sensor tab by carefully lifting it away from the hoverboard.
終わりに
Jesus
メンバー登録日: 2018年10月08日
85 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S13-G6, White Fall 2018 Cal Poly, Team S13-G6, White Fall 2018人のメンバー
CPSU-WHITE-F18S13G6
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 242
