はじめに
This guide explains how to replace the shell of your Hover-1 H1 hoverboard.
  1. Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Puncture the two black stickers by using the tip of a screwdriver.
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
    • Unplug the battery by pulling gently on both sides of the orange connector.
    • Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
    • Remove the vertical light from the shell by using your hands to pull it free from the surrounding shell.
    • Remove two 8mm screws using a Phillips #0 screwdriver to rotate the screws counterclockwise.
    • Remove the horizontal light by using your fingers to pull the light up out of the shell.
    • Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
    • Be careful to not damage the wires or connector when removing the glue.
    • Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
    • Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
    • It might be helpful to put the charger in the charging port while unscrewing the nut to ensure that the port is not spinning.
    • Pull the charging port to the left through the shell.
    • Unplug the power button connector by pinching the tab on the front and pulling directly upwards.
    • Pull the cable through the center section of the hoverboard.
    • For reassembly, you will have to feed the cable back through the center section. This can be done using a rigid wire or cable.
    • Using an adjustable wrench, remove the nut on the back of the power button by rotating the nut counterclockwise.
    • Pull the power button through the hole in the shell.
    • Remove the sixteen 10mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise.
    • Remove the two 12mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise.
    • Lift both the left and right sides of the top half of the shell from the hoverboard's chassis.
    • Remove the two 8mm Phillips #0 screws on the right half of the shell by using a screwdriver to rotate the screws counterclockwise.
    • Repeat for the left side of the shell.
    • Lift the shell to remove it from the chassis.
まとめ
Sara Passantino
メンバー登録日: 2018年10月08日
305 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018人のメンバー
CPSU-WHITE-F18S17G6
4 メンバー
7のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 16
今までの合計 41
