メインコンテンツにスキップ
Hover-1 H1 Gyroscope Sensor Assemblies Replacement
必要な工具と部品
  1. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Bottom Shell: 手順 1、 1の画像 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 2、 1の画像 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 3、 2の画像 1 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 3、 2の画像 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 4、 1の画像 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: 手順 5、 2の画像 1 Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: 手順 5、 2の画像 2
    • On the battery side of the hoverboard, remove the red, black, and purple sleeved cable from the sensor assembly by squeezing the tab and pulling up.
  6. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 6、 2の画像 1 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 6、 2の画像 2
    • Remove the red, blue, and green cable from the cable extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  7. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 7、 2の画像 1 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 7、 2の画像 2
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
  8. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 8、 1の画像 1
    • Remove the sensor assembly on the battery side of the hoverboard by gently lifting and pulling away from the hoverboard.
  9. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 9、 3の画像 1 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 9、 3の画像 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 9、 3の画像 3
    • Remove the hot glue holding in the connectors with a utility knife.
    • Remove the white cable from the sensor assembly by squeezing the connector and pulling the connector up.
    • Be careful not to touch any parts of the circuit boards with the knife.
  10. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 10、 1の画像 1
    • Remove the red, blue, and green cable from the extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  11. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 11、 2の画像 1 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 11、 2の画像 2
    • Remove the red and black sleeved connector from the sensor assembly by squeezing the tab and pulling up.
  12. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 12、 2の画像 1 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 12、 2の画像 2
  13. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 手順 13、 1の画像 1
    • Remove the sensor assembly on the motherboard side of the hoverboard by gently lifting and pulling away from the hoverboard.
終わりに
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Aaron Teh
メンバー登録日: 10/08/18
442 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018人のメンバー
CPSU-WHITE-F18S17G6
4 メンバー
7のガイドは作成済み
コメント 1 件
where can I get the replacement parts?
Rob Sayles - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 20
過去 30 日: 114
今までの合計 4,847
