メインコンテンツにスキップ
Hover-1 H1 Charging Port Replacement
必要な工具と部品
  1. Hover-1 H1 Charging Port Replacement, Bottom Shell: 手順 1、 1の画像 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Charging Port Replacement: 手順 2、 1の画像 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Charging Port Replacement: 手順 3、 2の画像 1 Hover-1 H1 Charging Port Replacement: 手順 3、 2の画像 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Charging Port Replacement: 手順 4、 1の画像 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Charging Port Replacement, Charging Port: 手順 5、 2の画像 1 Hover-1 H1 Charging Port Replacement, Charging Port: 手順 5、 2の画像 2
    • Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
    • Be careful to not damage the wires or connector when removing the glue.
  6. Hover-1 H1 Charging Port Replacement: 手順 6、 1の画像 1
    • Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
  7. Hover-1 H1 Charging Port Replacement: 手順 7、 2の画像 1 Hover-1 H1 Charging Port Replacement: 手順 7、 2の画像 2
    • Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
    • It might be helpful to put the charger in the charging port while unscrewing the nut to ensure that the port is not spinning.
  8. Hover-1 H1 Charging Port Replacement: 手順 8、 2の画像 1 Hover-1 H1 Charging Port Replacement: 手順 8、 2の画像 2
    • Pull the charging port to the left through the shell.
終わりに
作成者
1人の作成者と共同作成されました。
Madeline David
メンバー登録日: 10/08/18
280 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018人のメンバー
CPSU-WHITE-F18S17G6
4 メンバー
7のガイドは作成済み
コメント 1 件
I need to replace the charging port on my H1 hoverboard. Can you share the link for the actual replacement part.
prdrngga - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 52
今までの合計 3,866
