はじめに
This guide explains how to remove the bottom shell of your hoverboard, which will allow you to gain access to most of the device's internals.
必要な工具と部品
Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
もう少しです!
終わりに
