この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Replacing in the battery in your Hover-1 H1 hoverboard might help to solve charging problems.
必要な工具と部品
Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
4 の人々がこのガイドを完成させました。
11 件のコメント
After removing the 4 screws that is holding the battery in place I still can't remove the battery. I tried gently to pry under the battery but it doesn't budge. Uni Sun model HY-A01B. How do I solve this problem?
