はじめに
This guide will walk you through how to replace a faulty or non-functional LED headlight on a Hover-1 Eagle scooter. You should replace your headlight if your headlight no longer turns on or appears cracked or damaged. To determine if you need to replace your headlight, refer to our Troubleshooting Guide.
必要な工具と部品
Remove the four screws from the bottom side of the display housing using a Phillips #2 screwdriver.
終わりに
4 の人々がこのガイドを完成させました。
