メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Hover-1 Coast Power Button Spring Replacement
必要な工具と部品
  1. Hover-1 Coast Power Button Spring Replacement, Board Battery: 手順 1、 3の画像 1 Hover-1 Coast Power Button Spring Replacement, Board Battery: 手順 1、 3の画像 2 Hover-1 Coast Power Button Spring Replacement, Board Battery: 手順 1、 3の画像 3
    • To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board.
    • Using a pick tool, puncture the grip tape and expose the screws.
    • Loosen all four 1" screws using a Phillips #1 screwdriver.
    FixBotに聞いてみる
  2. Hover-1 Coast Power Button Spring Replacement: 手順 2、 3の画像 1 Hover-1 Coast Power Button Spring Replacement: 手順 2、 3の画像 2 Hover-1 Coast Power Button Spring Replacement: 手順 2、 3の画像 3
    • Now pull the black protective cover off the board.
    • Locate the battery.
    FixBotに聞いてみる
  3. Hover-1 Coast Power Button Spring Replacement: 手順 3、 3の画像 1 Hover-1 Coast Power Button Spring Replacement: 手順 3、 3の画像 2 Hover-1 Coast Power Button Spring Replacement: 手順 3、 3の画像 3
    • The battery is connected by these two sets of wires.
    • Remove the yellow wire first by pulling the two wires gently in opposite directions.
    • Now pull apart the black wire by gently pulling the two wires in opposite directions.
    FixBotに聞いてみる
  4. Hover-1 Coast Power Button Spring Replacement: 手順 4、 3の画像 1 Hover-1 Coast Power Button Spring Replacement: 手順 4、 3の画像 2 Hover-1 Coast Power Button Spring Replacement: 手順 4、 3の画像 3
    • Once the battery has been disconnected, gently pry the battery upward.
    • It is important to use a plastic opening tool to avoid puncturing the battery.
    • Once the battery is freed, remove it with your hands.
    • The battery is glued to the case and will require some effort to remove.
    FixBotに聞いてみる
  5. Hover-1 Coast Power Button Spring Replacement, Power Button Spring: 手順 5、 3の画像 1 Hover-1 Coast Power Button Spring Replacement, Power Button Spring: 手順 5、 3の画像 2 Hover-1 Coast Power Button Spring Replacement, Power Button Spring: 手順 5、 3の画像 3
    • Using the Phillips #1 screwdriver, loosen the two screws and place the power button somewhere safe.
    FixBotに聞いてみる
  6. Hover-1 Coast Power Button Spring Replacement: 手順 6、 2の画像 1 Hover-1 Coast Power Button Spring Replacement: 手順 6、 2の画像 2
    • Remove the unwanted spring and place your new spring back into the hole.
    FixBotに聞いてみる
終わりに
作成者
4人の作成者と共同で作成されました。
Jace Oppenlander
メンバー登録日: 10/04/18
569 ポイント
4のガイドは作成済み
チーム
Linn Benton Community College, Team S2-G2, Karnes Fall 2018 Linn Benton Community College, Team S2-G2, Karnes Fall 2018人のメンバー
LBCC-KARNES-F18S2G2
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 85
今までの合計 670
