メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This guide will show you how to replace the LED headlights on the front of the Hover-1 Chrome. You will need a Phillips #2 screwdriver.
パーツ
パーツは指定されていません。
  1. Flip the Hover-1 Chrome upside down.
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Lift the shell without the speaker grille and unplug the battery.
    • Lift the shell without the speaker grille and unplug the battery.
  3. iPhone LCDスクリーン修理キット
    生涯保証付きの低コストオプション
    キット商品を見る
    品質ではなく、修理コストを削減しましょう。
    キット商品を見る
  4. Lift the shell with the speaker grille. Unplug the speaker.
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  5. Use a Phillips #2 screwdriver to remove the two 2 mm screws on either side of the LEDs. Remove the LED board. The LEDs are not symmetrical. This step is for the right side of the board, next to the power button. The left side is covered next.
    • Use a Phillips #2 screwdriver to remove the two 2 mm screws on either side of the LEDs.
    • Remove the LED board.
    • The LEDs are not symmetrical. This step is for the right side of the board, next to the power button. The left side is covered next.
  6. Locate the LED headlights on the left side of the board. Pull the red wire attached to the LEDs perpendicular to the other wires to disconnect it.
    • Locate the LED headlights on the left side of the board.
    • Pull the red wire attached to the LEDs perpendicular to the other wires to disconnect it.
  7. Use a Phillips #2 screwdriver to remove the two 2 mm screws on either side of the LEDs. Remove the LED board. Remove the LED board.
終わりに
Nick McGuire
メンバー登録日: 2018年10月08日
548 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S4-G1, White Fall 2018 Cal Poly, Team S4-G1, White Fall 2018人のメンバー
CPSU-WHITE-F18S4G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 81
