メインコンテンツにスキップ
Hover 1 Eclipse Shell Replacement
必要な工具と部品
  1. Hover 1 Eclipse Shell Replacement, Shell: 手順 1、 3の画像 1 Hover 1 Eclipse Shell Replacement, Shell: 手順 1、 3の画像 2 Hover 1 Eclipse Shell Replacement, Shell: 手順 1、 3の画像 3
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
    • Remove the plug side bottom shell piece.
    • Be cautious of the wires connecting the plug side shell piece to the body. Do not pull the piece off until these wires have been disconnected in the following step.
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the remaining bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the remaining side bottom shell piece.
    • Remove final bottom shell piece
  2. Hover 1 Eclipse Shell Replacement: 手順 2、 3の画像 1 Hover 1 Eclipse Shell Replacement: 手順 2、 3の画像 2 Hover 1 Eclipse Shell Replacement: 手順 2、 3の画像 3
    • On the bottom plug side shell pieces, there are two white and pink wires connecting the shell and the motherboard.
    • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
    • Follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
    • Now you can fully remove the bottom plug side shell piece.
  3. Hover 1 Eclipse Shell Replacement: 手順 3、 1の画像 1
    • Unplug the yellow tipped plug attached to the red and black cord on the non-battery side.
  4. Hover 1 Eclipse Shell Replacement: 手順 4、 1の画像 1
    • Using a Phillips #1 Screwdriver, remove the twelve 11mm and 13mm screws that line the bottom inside of the battery side of the Hover-1 Eclipse.
    • The screw placement is mirrored on the other side
    • Repeat these steps for the left inside of the Hover-1 Eclipse.
  5. Hover 1 Eclipse Shell Replacement: 手順 5、 3の画像 1 Hover 1 Eclipse Shell Replacement: 手順 5、 3の画像 2 Hover 1 Eclipse Shell Replacement: 手順 5、 3の画像 3
    • Push down the shell and LED light near the center of the board as shown.
    • In the newly exposed area, there will be an 11mm screw holding in the wire that connects to the LED light of the frame. Remove this screw.
    • Now separate the light from the shell and board.
    • Repeat this for the other 3 lights.
  6. Hover 1 Eclipse Shell Replacement: 手順 6、 2の画像 1 Hover 1 Eclipse Shell Replacement: 手順 6、 2の画像 2
    • Follow the rainbow cord that connects the left side shell piece to the inside board. Find where it is plugged into and disconnect it.
    • The cord is a bundle of multicolored wires sheathed in black, halfway down.
    • Follow the black and blue cord that connects the left side shell piece to the inside board. Find where it is plugged into and disconnect it.
    • Repeat for the top right shell piece.
    • Remove both shell pieces.
終わりに
作成者
4人の作成者と共同で作成されました。
Stone Burgan
メンバー登録日: 10/10/19
133 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S12-G4, Regan Fall 2019 Cal Poly, Team S12-G4, Regan Fall 2019人のメンバー
CPSU-REGAN-F19S12G4
4 メンバー
5のガイドは作成済み
コメント 1 件
Where can I buy the shell please help me
luke - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 996
