メインコンテンツにスキップ
Hover 1 Eclipse Motherboard Replacement
必要な工具と部品
  1. Hover 1 Eclipse Motherboard Replacement, Motherboard: 手順 1、 3の画像 1 Hover 1 Eclipse Motherboard Replacement, Motherboard: 手順 1、 3の画像 2 Hover 1 Eclipse Motherboard Replacement, Motherboard: 手順 1、 3の画像 3
    • Using a Phillips #1 Screwdriver, remove the eight 11mm screws that surround the edge of each shell piece.
    • Using a Phillips #1 Screwdriver, remove the eight 13mm screws that surround the edge of both shell pieces.
    • Remove the right side bottom shell piece.
  2. Hover 1 Eclipse Motherboard Replacement: 手順 2、 3の画像 1 Hover 1 Eclipse Motherboard Replacement: 手順 2、 3の画像 2 Hover 1 Eclipse Motherboard Replacement: 手順 2、 3の画像 3
    • On the bottom, left side, shell pieces, there are some white and pink wires connecting the shell and the motherboard.
    • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
    • Follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
    • Now you can fully remove the bottom left shell piece.
  3. Hover 1 Eclipse Motherboard Replacement: 手順 3、 1の画像 1
    • Unplug the yellow tipped plug, Xt60, attached to the red and black cord on the non-battery side.
  4. Hover 1 Eclipse Motherboard Replacement: 手順 4、 3の画像 1 Hover 1 Eclipse Motherboard Replacement: 手順 4、 3の画像 2 Hover 1 Eclipse Motherboard Replacement: 手順 4、 3の画像 3
    • Unplug the yellow tipped plug attached to the red and black cords.
    • Unplug the black headers attached to the white, skinny cord.
    • Unplug the green, blue and yellow plugs by pressing down the silver, under the clear plastic and pulling it apart.
  5. Hover 1 Eclipse Motherboard Replacement: 手順 5、 2の画像 1 Hover 1 Eclipse Motherboard Replacement: 手順 5、 2の画像 2
    • Unplug the white header attached to the pink and white cord.
    • Using a Phillips #1 screwdriver, remove the four screws from each corner of the motherboard.
    • Repeat steps 3 and 4 on the other side.
  6. Hover 1 Eclipse Motherboard Replacement: 手順 6、 1の画像 1
    • You have now removed the motherboards from both sides.
終わりに
作成者
3人の作成者と共同で作成されました。
Mina Dedijer
メンバー登録日: 10/10/19
548 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S12-G4, Regan Fall 2019 Cal Poly, Team S12-G4, Regan Fall 2019人のメンバー
CPSU-REGAN-F19S12G4
4 メンバー
5のガイドは作成済み
7件のガイドコメント
Can you please drop links to purchase the 2 motherboards?
Frank - 返信
Hi
wondering if you know the part numbers and where to obtain the boards?
Dave - 返信
We’re do you get the boards at I really need them
Ashton Mcalvain - 返信
We’re do get the boards?
Hector Ortiz - 返信
Any idea where to buy parts and the price?
william bowen - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 16
今までの合計 2,347
