はじめに
This guide will walk you through replacing the battery in your Hott T725-8G.
必要な工具と部品
Remove the back of the device using the Plastic Opening tool by placing it between the front and back panel and gently prying them apart.
Remove the yellow tape holding the wire connecting the battery to the motherboard with your fingers.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
