メインコンテンツにスキップ
Hot Wheels AI Intelligent Race System Controller Transmitter Replacement
必要な工具と部品
  1. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement, Controller Transmitter: 手順 1、 1の画像 1
    • Locate and remove the six screws on the back of the controller. Remove screws with a #J1 Philips head screwdriver.
  2. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: 手順 2、 1の画像 1
    • With the controller facing down remove the top casing from the bottom. Do this by popping the casing lose which will expose the inside circuits.
  3. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: 手順 3、 1の画像 1
    • With the circuits exposed locate the transmitter at the top of the controller. It is green hue in comparison to the rest of the blue circuits. Check the transmitter for damage or disconnected wires.
  4. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: 手順 4、 1の画像 1
    • If transmitter has broken or has disconnected wires it may need replacement. Wires can easily break loose from the transmitter. The wires can easily be reinserted by sticking the wire back into its original slot.
  5. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: 手順 5、 1の画像 1
    • If the transmitter is damaged, replace it by sliding the circuit down from its slot. Check for damage or burned out circuit.
    • Replace transmitter circuit with a new one by reinserting it into the original slot.
終わりに
作成者
2人の作成者と共同で作成されました。
Luke Marshall
メンバー登録日: 09/07/18
628 ポイント
4のガイドは作成済み
チーム
Appalachian State University, Team S1-G2, Menagarishvili Fall 2018 Appalachian State University, Team S1-G2, Menagarishvili Fall 2018人のメンバー
APSU-MENAGARISHVILI-F18S1G2
2 メンバー
6のガイドは作成済み
1件のガイドコメント
Give the part numbers so we can source the circuits and change the devices if needed. Also can anyone extract the rim? I believe the rim being used is way low quality.
Luis Vitorio Cargnini - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 23
今までの合計 1,099
