はじめに
Below we have outlined a few issues that we plan to address based on the research that we have conducted.
• Heating coil burn out
• Temperature control switch burn out
• On/Off switch burn out
必要な工具と部品
Ensure that you have a clean work station, and that you can easily keep track of small, loose parts.
In addition, MAKE SURE IT IS UNPLUGGED FOR ALL FOLLOWING STEPS!
この手順で使用する道具:Tweezers$4.99
Firmly grasp the end of the Iron with the black plastic cap on the heating element end.
With your free hand, use tweezers to firmly grasp the small retaining ring sitting between the heating element and the handle body.
Once you have a firm grasp, pull up on the retaining ring, and it should come loose.
2 件のコメント
How can I tighten the clamp?
where can i get or order the part for the (spring with small roller)
i have a model ht1110xl hot tools iron
