メインコンテンツにスキップ
Hot Tools HPK12 Heating Plate Replacement
必要な工具と部品
  1. Hot Tools HPK12 Heating Plate Replacement, Prerequisite Only: 手順 1、 3の画像 1 Hot Tools HPK12 Heating Plate Replacement, Prerequisite Only: 手順 1、 3の画像 2 Hot Tools HPK12 Heating Plate Replacement, Prerequisite Only: 手順 1、 3の画像 3
    • Remove round plastic cover near cord base by prying under the side with the metal spudger.
    • Flip the device and remove the other round plastic cover near the base of the cord.
    • Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
  2. Hot Tools HPK12 Heating Plate Replacement: 手順 2、 1の画像 1
    • Use the metal spudger to push the center pin through to the other side.
  3. Hot Tools HPK12 Heating Plate Replacement: 手順 3、 2の画像 1 Hot Tools HPK12 Heating Plate Replacement: 手順 3、 2の画像 2
    • Lift back plastic cover to expose spring assembly.
    • Be careful not to damage the power cord by bending or twisting it too much while performing this step.
    • Grip the exposed end of the spring assembly and remove it.
    • The side with the two ends of the spring goes into the recessed area of the iron
  4. Hot Tools HPK12 Heating Plate Replacement: 手順 4、 1の画像 1
    • Use the JIS #0 screwdriver to remove the two 3.5mm “J0” screws that attach the control assembly cover to the flat iron base.
  5. Hot Tools HPK12 Heating Plate Replacement: 手順 5、 3の画像 1 Hot Tools HPK12 Heating Plate Replacement: 手順 5、 3の画像 2 Hot Tools HPK12 Heating Plate Replacement: 手順 5、 3の画像 3
    • Lift upward on the control assembly cover to remove it from the flat iron base.
    • Remove dial and switch cover and set aside.
  6. Hot Tools HPK12 Heating Plate Replacement: 手順 6、 3の画像 1 Hot Tools HPK12 Heating Plate Replacement: 手順 6、 3の画像 2 Hot Tools HPK12 Heating Plate Replacement: 手順 6、 3の画像 3
    • Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
    • Lift the backing plate upwards to remove it from the flat iron.
    • Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
  7. Hot Tools HPK12 Heating Plate Replacement, Heating Plates: 手順 7、 1の画像 1
    • Lift plate and circuit assembly away from flat iron case.
  8. Hot Tools HPK12 Heating Plate Replacement: 手順 8、 1の画像 1
    • Flip device to access the non-control assembly flat iron arm and remove two 3.5mm “J0” screws that attaches cover to flat iron base.
  9. Hot Tools HPK12 Heating Plate Replacement: 手順 9、 1の画像 1
    • Lift cover from flat iron case.
  10. Hot Tools HPK12 Heating Plate Replacement: 手順 10、 2の画像 1 Hot Tools HPK12 Heating Plate Replacement: 手順 10、 2の画像 2
    • Lift heating plate away from flat iron case.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Nathan Schwartz
メンバー登録日: 10/24/16
318 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 3-4, Baechle Fall 2016 IUPUI, Team 3-4, Baechle Fall 2016人のメンバー
IUPUI-BAECHLE-F16S3G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 877
