メインコンテンツにスキップ
Hoover Windtunnel Air Steerable Upright Motor Assembly Replacement
必要な工具と部品
  1. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: 手順 1、 2の画像 1 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: 手順 1、 2の画像 2
    • Put the cleaner into the upright position, turn the power off, and unplug the power cord.
  2. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 手順 2、 3の画像 1 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 手順 2、 3の画像 2 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 手順 2、 3の画像 3
    • Remove the dirt cup from the cleaner.
    • The HEPA filter is located under the dirt cup and under where it says HEPA.
    • Twist the top counterclockwise to unlock the cap.
  3. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 手順 3、 2の画像 1 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 手順 3、 2の画像 2
    • Lift the HEPA filter out.
    • Tap the filter against the inside of a trashcan to knock out the dirt and debris or replace as necessary.
    • Do not wash the HEPA Filter.
  4. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: 手順 4、 3の画像 1 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: 手順 4、 3の画像 2 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: 手順 4、 3の画像 3
    • Remove the 4 retaining screws and remove the filter tray.
    • Screw lengths are approximately 3/4".
  5. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 手順 5、 1の画像 1
    • Pull the motor housing vertically to dislodge the motor.
  6. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 手順 6、 3の画像 1 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 手順 6、 3の画像 2 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 手順 6、 3の画像 3
    • Use a plastic spudger or opening tool to press on the small circle and wiggle clips free.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
steven hoover
メンバー登録日: 09/26/17
257 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S7-G2, Banghart Fall 2017 Cal Poly, Team S7-G2, Banghart Fall 2017人のメンバー
CPSU-BANGHART-F17S7G2
5 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 85
今までの合計 3,019
