メインコンテンツにスキップ
Hoover WindTunnel 2 Rewind Leaky Hose Replacement
必要な工具と部品
  1. Hoover WindTunnel 2 Rewind Leaky Hose Replacement, Leaky Hose: 手順 1、 1の画像 1
    • Detach the top of the hose from the device by pressing the release button and pulling up on the hose.
  2. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: 手順 2、 1の画像 1
    • Remove the other end of the hose by twisting the hose clockwise and pulling it off.
  3. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: 手順 3、 1の画像 1
    • Firmly insert the larger end of the replacement hose into the upward facing hole in the vacuum.
  4. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: 手順 4、 1の画像 1
    • Line up the smaller end of the hose and insert it into the downward facing hole.
    • Twist the hose until it locks.
終わりに
The Hoover Windtunnel 2 Rewind must have a solid and functional hose to work correctly. With this set of instructions, it is easy to replace a leaky hose.
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Mickey McGuire
メンバー登録日: 01/22/18
253 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S11-G4, Banghart Winter 2018 Cal Poly, Team S11-G4, Banghart Winter 2018人のメンバー
CPSU-BANGHART-W18S11G4
5 メンバー
10のガイドは作成済み
6 件のコメント
Good job, helpful. Thanks!
Celeste Williams-Hughes - 返信
Thanks, I'm stuck in quarantine and can't go out to get mine fixed, so I'm so glad I found this. Especially since it was just my hose being filled to the brim with dog hair!
Taylore Kirk - 返信
Same issue. Easy fix thanks!
mark camirand - 返信
That’s great instructions but it’s not even 8 months old. This has happened from day one!!
Linda Schindler - 返信
How long does it take to cool off and turn back on after removing the clog?
Victoria Tingwall - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 54
今までの合計 28,826
