メインコンテンツにスキップ
Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement
必要な工具と部品
  1. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement, Height Adjustment Wheels: 手順 1、 2の画像 1 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement, Height Adjustment Wheels: 手順 1、 2の画像 2
    • Place the vacuum on its back.
    • Push the red switch to the left.
    • The black cover will then pop out. Remove the cover.
  2. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 手順 2、 3の画像 1 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 手順 2、 3の画像 2 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 手順 2、 3の画像 3
    • Locate the red switch near the head of the vacuum.
    • Push the switch left.
    • This will pop out the plastic base plate. Remove the plate from the vacuum.
  3. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 手順 3、 3の画像 1 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 手順 3、 3の画像 2 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 手順 3、 3の画像 3
    • Use a Phillips #1 screwdriver to remove the screws from the right side of the white plastic frame.
  4. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 手順 4、 3の画像 1 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 手順 4、 3の画像 2 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 手順 4、 3の画像 3
    • Remove screws from the left side of the white plastic frame.
  5. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 手順 5、 3の画像 1 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 手順 5、 3の画像 2 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 手順 5、 3の画像 3
    • Pull the white plastic frame away from the vacuum.
    • Slide the vacuum belt off the metal rod.
    • Pull the brush off the vacuum.
  6. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 手順 6、 2の画像 1 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 手順 6、 2の画像 2
    • Remove the screws at the bottom of the white frame near the roller.
  7. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 手順 7、 3の画像 1 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 手順 7、 3の画像 2 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 手順 7、 3の画像 3
    • Pop off the right side of the white frame.
    • Pull down the blue hinge and roller.
    • Pull free the roller from the vacuum.
終わりに
作成者
2人の作成者と共同で作成されました。
Nathan Yung
メンバー登録日: 01/18/18
241 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S12-G4, Banghart Winter 2018 Cal Poly, Team S12-G4, Banghart Winter 2018人のメンバー
CPSU-BANGHART-W18S12G4
5 メンバー
9のガイドは作成済み
2 件のコメント
HOOVER 30310 brush roller stops when the handle is released for vacuuming. Begins again when handle raised and locked into upright position.
David Blair - 返信
Hoover wind tunnel three pet quick pass. Roller spins in an upright position (locked handle). Foot pedal tensioner and off works, but will not stay in off position.
Kirk Teichert - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 16
過去 30 日: 51
今までの合計 2,443
