はじめに
This guide will show how to replace the battery, this should be done if the robot vacuum cleaner starts getting a short runtime and often need to recharge.
You could also need to replace the battery if you have had the robot standing unused for a long time and it doesn't run for long/not at all.
必要な工具と部品
Unscrew the two 9.5mm Phillips #2 screws.
Remove the battery lid using your fingers.
もう少しです!
終わりに
