メインコンテンツにスキップ
Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement
必要な工具と部品
  1. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement, Rotating Brush Roll: 手順 1、 2の画像 1 Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement, Rotating Brush Roll: 手順 1、 2の画像 2
    • Press grey release button on stick vacuum to release vacuum head.
  2. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: 手順 2、 3の画像 1 Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: 手順 2、 3の画像 2 Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: 手順 2、 3の画像 3
    • Locate the circular black turn switch, which is in the upper right corner of the backside of the vacuum head
    • Using a metal spudger, place the tool in the indent of the circular turn switch and turn it from the left to the right or from the "locked" symbol to the "unlocked" symbol
  3. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: 手順 3、 2の画像 1 Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: 手順 3、 2の画像 2
    • Flip the vacuum head over so that the wheels and screws are facing you.
    • Using a PH #1 screw driver, remove the four 15mm screws from each corner of the backside of the vacuum head.
  4. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: 手順 4、 3の画像 1 Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: 手順 4、 3の画像 2 Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: 手順 4、 3の画像 3
    • Locate the two wheels in the upper half of the vacuum head and remove them by sticking the metal spudger tool underneath the wheel and pushing it towards you until it pops out.
    • Remove the two 15mm screws located under the wheels with a PH #1 screw driver.
  5. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: 手順 5、 3の画像 1 Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: 手順 5、 3の画像 2 Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: 手順 5、 3の画像 3
    • Using a firm grip, pull the two halves of the vacuum head away from each other until they are completely separated
  6. Hoover Presto 2-in-1 Cordless Stick Rotating Brush Roll Replacement: 手順 6、 1の画像 1
    • Remove brush from inside the vacuum head.
終わりに
作成者
3人の作成者と共同で作成されました。
katia zubieta
メンバー登録日: 09/11/17
437 ポイント
4のガイドは作成済み
チーム
CSU Fullerton, Team S2-G6, Bruce Fall 2017 CSU Fullerton, Team S2-G6, Bruce Fall 2017人のメンバー
CSUF-BRUCE-F17S2G6
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 8
今までの合計 617
