メインコンテンツにスキップ
Hoover Presto 2-in-1 Cordless Stick Charger Replacement
必要な工具と部品
  1. Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: 手順 1、 3の画像 1 Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: 手順 1、 3の画像 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: 手順 1、 3の画像 3
    • Using a firm grip, gently pull the standing charger away from the floor charger attachment
  2. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 手順 2、 2の画像 1 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 手順 2、 2の画像 2
    • Flip the floor charger over so the screws and sticker are facing you
    • Using a PH #1 screw driver, remove the two 18mm screws on the right hand side of the floor charger
  3. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 手順 3、 2の画像 1 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 手順 3、 2の画像 2
    • Using a PH #2 screw driver, remove the three 18mm screws on floor charger.
  4. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 手順 4、 2の画像 1 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 手順 4、 2の画像 2
    • Using the metal spudger tool, gently lift up the plastic cover in the upper right hand corner of the floor attachment to uncover a hidden screw
    • Remove the 18mm screw in the upper right hand corner with a PH #1 screw driver
  5. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 手順 5、 2の画像 1 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 手順 5、 2の画像 2
    • Using the metal spudger, gently pry open the two halves of the floor charger
    • Once you have made a larger enough gap between the two halves, use your hands and gently pull the rest of the floor charger apart
  6. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 手順 6、 1の画像 1
    • Unscrew the two 18mm screws on either side of the white battery cover with a PH #1 screw driver
  7. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 手順 7、 2の画像 1 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 手順 7、 2の画像 2
    • Using your hands, gently pull apart the two halves of the white battery cover to get to the battery
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
katia zubieta
メンバー登録日: 09/11/17
437 ポイント
4のガイドは作成済み
チーム
CSU Fullerton, Team S2-G6, Bruce Fall 2017 CSU Fullerton, Team S2-G6, Bruce Fall 2017人のメンバー
CSUF-BRUCE-F17S2G6
3 メンバー
8のガイドは作成済み
4 件のコメント
La pila dónde la puedo encontrar
alejandro rodriguez - 返信
De la aspiradora Hoover presto 2 un 1
I followed the directions above and got it opened. There was no battery inside. What do I do???? This is for the Hoover Presto 2in1. Thank you.
silvmarg - 返信
Where does one buy the replacement battery?
mytikikitty - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 24
今までの合計 6,079
