メインコンテンツにスキップ
Hoover Power Path Pro Advanced Suction Motor Replacement
必要な工具と部品
  1. Hoover Power Path Pro Advanced Suction Motor Replacement, Brush Roller: 手順 1、 2の画像 1 Hoover Power Path Pro Advanced Suction Motor Replacement, Brush Roller: 手順 1、 2の画像 2
    • Unplug the vacuum cleaner from the wall outlet before starting. Make sure the water tanks are empty.
    • Lay the cleaner down horizontally with its wheels closest to the floor.
  2. Hoover Power Path Pro Advanced Suction Motor Replacement: 手順 2、 2の画像 1 Hoover Power Path Pro Advanced Suction Motor Replacement: 手順 2、 2の画像 2
    • Hold the lower brush roll with both hands and pull outwards until it is detached.
  3. Hoover Power Path Pro Advanced Suction Motor Replacement: 手順 3、 1の画像 1
    • Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
    • Remove the brush roller.
  4. Hoover Power Path Pro Advanced Suction Motor Replacement, Belt: 手順 4、 1の画像 1
    • Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
  5. Hoover Power Path Pro Advanced Suction Motor Replacement: 手順 5、 2の画像 1 Hoover Power Path Pro Advanced Suction Motor Replacement: 手順 5、 2の画像 2
    • Pull the red handle shown to remove the front suction unit from the cleaner.
  6. Hoover Power Path Pro Advanced Suction Motor Replacement: 手順 6、 1の画像 1
    • Unscrew the Phillips #2 screw at the bottom of the hose.
  7. Hoover Power Path Pro Advanced Suction Motor Replacement: 手順 7、 2の画像 1 Hoover Power Path Pro Advanced Suction Motor Replacement: 手順 7、 2の画像 2
    • Push down on the handle release button. Pull and disconnect the edge of the top cover on the side of the handle release button.
    • Repeat the above step for the "On/Off" button.
    • When pulling the handle release button, make sure the top of the cleaner does not fall.
  8. Hoover Power Path Pro Advanced Suction Motor Replacement: 手順 8、 1の画像 1
    • Gently grab the belt and pry it off from the rollers.
  9. Hoover Power Path Pro Advanced Suction Motor Replacement, Suction Motor: 手順 9、 2の画像 1 Hoover Power Path Pro Advanced Suction Motor Replacement, Suction Motor: 手順 9、 2の画像 2
    • Unscrew two screws using Phillips #2 screwdriver.
    • Detach grey piece from vacuum.
  10. Hoover Power Path Pro Advanced Suction Motor Replacement: 手順 10、 2の画像 1 Hoover Power Path Pro Advanced Suction Motor Replacement: 手順 10、 2の画像 2
    • Unscrew four screws using a Phillips 2 screwdriver.
  11. Hoover Power Path Pro Advanced Suction Motor Replacement: 手順 11、 1の画像 1
    • Pull out of base of vacuum.
  12. Hoover Power Path Pro Advanced Suction Motor Replacement: 手順 12、 1の画像 1
    • Flip vacuum over and unscrew three screws with a Phillips #2 screwdriver.
  13. Hoover Power Path Pro Advanced Suction Motor Replacement: 手順 13、 1の画像 1
    • Unscrew two screws with Phillips #2 screwdriver.
  14. Hoover Power Path Pro Advanced Suction Motor Replacement: 手順 14、 1の画像 1
    • Detach motor and unscrew two screws with a Phillips #2 screwdriver.
  15. Hoover Power Path Pro Advanced Suction Motor Replacement: 手順 15、 2の画像 1 Hoover Power Path Pro Advanced Suction Motor Replacement: 手順 15、 2の画像 2
    • Pull the bottom section off.
    • Pull the cap off.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jose Andres Gonzalez Valdes
メンバー登録日: 01/22/18
682 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S16-G5, Banghart Winter 2018 Cal Poly, Team S16-G5, Banghart Winter 2018人のメンバー
CPSU-BANGHART-W18S16G5
5 メンバー
15のガイドは作成済み
1件のガイドコメント
What to do if the motor is still good but the cooling fan on the top of the armature has broken off?
Billy H. Deal Jr - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 2,584
