はじめに
This guide will show you how to replace the wheels of your device. This would be needed if your device fails to roll on the flooring or if they simply broke apart. Be sure to remove the battery from the device and switch the power off.
必要な工具と部品
Detach the rolling assembly from the body by pushing the button found at the base.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
