メインコンテンツにスキップ
Honeywell Turboforce Motor Replacement
必要な工具と部品
  1. Honeywell Turboforce Motor Replacement, Motor: 手順 1、 3の画像 1 Honeywell Turboforce Motor Replacement, Motor: 手順 1、 3の画像 2 Honeywell Turboforce Motor Replacement, Motor: 手順 1、 3の画像 3
    • Using a Phillips #1 screwdriver, remove the six 15mm screws on the outer ring of the back of the fan holding the frame together.
    • The screw channel is long and it is recommended to use a screwdriver with a long shaft or a screwdriver with a skinnier handle.
  2. Honeywell Turboforce Motor Replacement: 手順 2、 3の画像 1 Honeywell Turboforce Motor Replacement: 手順 2、 3の画像 2 Honeywell Turboforce Motor Replacement: 手順 2、 3の画像 3
    • Pry apart the blade cover from the body of the fan to access the inside.
  3. Honeywell Turboforce Motor Replacement: 手順 3、 2の画像 1 Honeywell Turboforce Motor Replacement: 手順 3、 2の画像 2
    • Remove the two 36mm screws on the metal plate behind the blades using the Phillips #1 screwdriver.
  4. Honeywell Turboforce Motor Replacement: 手順 4、 2の画像 1 Honeywell Turboforce Motor Replacement: 手順 4、 2の画像 2
    • Carefully pull the motor forward out of its resting position and tilt it forward revealing the back of the motor.
    • Beware of the wires attached to the back of the motor.
  5. Honeywell Turboforce Motor Replacement: 手順 5、 3の画像 1 Honeywell Turboforce Motor Replacement: 手順 5、 3の画像 2 Honeywell Turboforce Motor Replacement: 手順 5、 3の画像 3
    • Using the Phillips #1 screwdriver, remove the two 37mm screws on the back of the motor.
    • Beware that there is a nut holding the screw in place on the opposite side of the motor.
    • Beware once the screw is removed the metal brace where the screws are located will come off.
  6. Honeywell Turboforce Motor Replacement: 手順 6、 2の画像 1 Honeywell Turboforce Motor Replacement: 手順 6、 2の画像 2
    • Carefully remove the circular motor from the square holder.
    • The fan blades will still be connected to the circular motor.
  7. Honeywell Turboforce Motor Replacement: 手順 7、 3の画像 1 Honeywell Turboforce Motor Replacement: 手順 7、 3の画像 2 Honeywell Turboforce Motor Replacement: 手順 7、 3の画像 3
    • Remove the felt washer, metal washer, and the rubber stopper from the axle.
  8. Honeywell Turboforce Motor Replacement: 手順 8、 1の画像 1
    • Remove the motor and replace it with the new part.
    • Consider using a lubricant to insert the new motor.
終わりに
11 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jake Hallem
メンバー登録日: 09/18/19
293 ポイント
1ガイドが承認済み
チーム
6件のガイドコメント
What is the motor parts details to procure elsewhere?
patra gyanesh - 返信
Hi informative guide but first how do we get the new motor how do you remove the blade nut to remove the blade from the old motor shaft
Dave Gordon - 返信
Given the difficulty of finding a replacement motor with three speeds and the correct mounting configuration, it makes more sense to buy a new model of this fan. Much faster, too.
Sprockets John
John Sprockets - 返信
Top notch how to document! Commentary and photos are excellent. Good job! And thank you very much
M Robarton - 返信
Where are y’all finding the motor? Please advise… this looks doable! Thank you for your assistance. Michelle
Michelle Paredes - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 17
過去 30 日: 110
今までの合計 9,552
