メインコンテンツにスキップ
Honeywell Pro 3000 Non-Programmable Thermostat Replacement
必要な工具と部品
  1. Honeywell Pro 3000 Non-Programmable Thermostat Replacement, Thermostat: 手順 1、 2の画像 1 Honeywell Pro 3000 Non-Programmable Thermostat Replacement, Thermostat: 手順 1、 2の画像 2
    • Find which switch on your circuit breaker is associated with your heating system. The number will match the number next to the breaker.
    • Turn the switch from on to off. Disconnecting the electricity to the thermostat.
  2. Honeywell Pro 3000 Non-Programmable Thermostat Replacement: 手順 2、 2の画像 1 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: 手順 2、 2の画像 2
    • On the thermostat being replaced. Unscrew each terminal with a Phillips #0 screwdriver until there is enough room for you to pull out each wire. Pull each wire until it is completely removed from terminal.
  3. Honeywell Pro 3000 Non-Programmable Thermostat Replacement: 手順 3、 1の画像 1
    • Once all wires are disconnected start to remove the base and wall mount from the wall. Remove each screw using a Phillips #0 screwdriver on both sides of the base and gently pull the base and mount from the wall.
  4. Honeywell Pro 3000 Non-Programmable Thermostat Replacement: 手順 4、 3の画像 1 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: 手順 4、 3の画像 2 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: 手順 4、 3の画像 3
    • To make sure the new thermostat is not crooked along the wall use a level on top of the plate. While holding the plate straight, screw in both 15.24mm X 25.4mm screws using a Phillips #0 screwdriver on the left and right side of the base place until it is fastened against the wall.
  5. Honeywell Pro 3000 Non-Programmable Thermostat Replacement: 手順 5、 3の画像 1 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: 手順 5、 3の画像 2 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: 手順 5、 3の画像 3
    • Place each colored wire gently into the corresponding terminal port until you can feel it hit the bottom of each port. All of the terminal ports are assigned by the first letter of each color coated wire.
    • It is not necessary to plug the blue wire in if you are using batteries for the thermostat.
  6. Honeywell Pro 3000 Non-Programmable Thermostat Replacement: 手順 6、 3の画像 1 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: 手順 6、 3の画像 2 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: 手順 6、 3の画像 3
    • Once all the wires are placed into the corresponding ports continue to secure the connection by using a flat head screwdriver to tighten the wires into the ports.
    • Once completed place the actual thermostat on the base plate.
  7. Honeywell Pro 3000 Non-Programmable Thermostat Replacement: 手順 7、 3の画像 1 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: 手順 7、 3の画像 2 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: 手順 7、 3の画像 3
    • Go to the circuit breaker and turn the electricity back onto the furnace and thermostat.
    • Mount the thermostat onto the wall plate and give the thermostat a test run to see if it functioning correctly.
終わりに
If the thermostat is not functioning as intended, take apart and reinstall making sure wire connections are secure.
作成者
1人の作成者と共同作成されました。
Samuel Covert
メンバー登録日: 03/23/20
145 ポイント
1ガイドが承認済み
チーム
Purdue University Northwest, Team S1-G10, Hingst Spring 2020 Purdue University Northwest, Team S1-G10, Hingst Spring 2020人のメンバー
PNW-HINGST-S20S1G10
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 43
今までの合計 2,744
