メインコンテンツにスキップ
Honeywell HY-254-TGT Front Panel Replacement
必要な工具と部品
  1. Honeywell HY-254-TGT Front Panel Replacement, Plastic Assembly: 手順 1、 1の画像 1
    • Remove the two 3/4" wing screws on the bottom of the fan by rotating them counter-clockwise.
  2. Honeywell HY-254-TGT Front Panel Replacement: 手順 2、 3の画像 1 Honeywell HY-254-TGT Front Panel Replacement: 手順 2、 3の画像 2 Honeywell HY-254-TGT Front Panel Replacement: 手順 2、 3の画像 3
    • Twist the fan base counter-clockwise until the pins line up as shown.
    • Pull the base straight towards you to remove it, feeding the wire through the base.
  3. Honeywell HY-254-TGT Front Panel Replacement: 手順 3、 1の画像 1
    • Remove all of the marked 1/2" Phillips #02 screws on the backside of the fan
    • Remove the two marked 3/4" Phillips #02 screws in the middle.
  4. Honeywell HY-254-TGT Front Panel Replacement: 手順 4、 3の画像 1 Honeywell HY-254-TGT Front Panel Replacement: 手順 4、 3の画像 2 Honeywell HY-254-TGT Front Panel Replacement: 手順 4、 3の画像 3
    • Use a plastic opening tool or screwdriver to pry off the back of the fan, starting from the top down.
    • Be aware of two clips inside the fan, towards the bottom third of the fan. If the back appears stuck on certain spots, push inward edges of the front casing around the problematic area.
  5. Honeywell HY-254-TGT Front Panel Replacement, Front Panel: 手順 5、 2の画像 1 Honeywell HY-254-TGT Front Panel Replacement, Front Panel: 手順 5、 2の画像 2
    • Remove the four 1/2" Phillips #02 screws, indicated by a red circle.
    • Lean the front panel forwards and set it down.
    • The front panel will not fully detach and cannot be removed. Do not try to forcibly remove it, as it may cause damage to the electronics.
  6. Honeywell HY-254-TGT Front Panel Replacement: 手順 6、 2の画像 1 Honeywell HY-254-TGT Front Panel Replacement: 手順 6、 2の画像 2
    • Gently lift and remove the panel covering the electronics assembly.
  7. Honeywell HY-254-TGT Front Panel Replacement: 手順 7、 3の画像 1 Honeywell HY-254-TGT Front Panel Replacement: 手順 7、 3の画像 2 Honeywell HY-254-TGT Front Panel Replacement: 手順 7、 3の画像 3
    • Remove the four 1/2" Phillips #01 screws in the circuit board.
    • Gently pull the circuit board off of the rest of the front panel assembly.
  8. Honeywell HY-254-TGT Front Panel Replacement: 手順 8、 3の画像 1 Honeywell HY-254-TGT Front Panel Replacement: 手順 8、 3の画像 2 Honeywell HY-254-TGT Front Panel Replacement: 手順 8、 3の画像 3
    • Lift out the internal part of the front panel to access the buttons.
  9. Honeywell HY-254-TGT Front Panel Replacement: 手順 9、 1の画像 1
    • If necessary, remove the buttons by grabbing them with two fingers and pulling up and away from the panel.
    • Upon reassembly, ensure buttons are placed in the correct location.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Darian Maxwell
メンバー登録日: 10/01/15
381 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 11-6, Forte Fall 2015 Cal Poly, Team 11-6, Forte Fall 2015人のメンバー
CPSU-FORTE-F15S11G6
4 メンバー
4のガイドは作成済み
2 件のコメント
the piece to make it turn is broken
clara rojas - 返信
the piece that make it turn is broken!
clara rojas - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 20
今までの合計 5,330
