はじめに
If you are having trouble with your Febreze scent settings, and you are sure that your scent cartridge is full, this is the guide for you! This guide will walk you through replacing the Febreze settings dial. Although this is a quick process, you need to be careful not to accidentally separate the wires from the dial.
必要な工具と部品
Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
もう少しです!
終わりに
