はじめに
This guide will walk you through the removal of your fan motor. It should be fairly easy, although you will need to crimp the wires to remove the motor.
必要な工具と部品
Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
Remove the four 12.7mm screws using the Phillips #0 Screwdriver.
Once the screws are removed, lift the motor off its base.
2 の人々がこのガイドを完成させました。
