はじめに
This guide will walk you through the removal of your fan motor. It should be fairly easy, although you will need to crimp the wires to remove the motor.
  1. Remove the four 14 mm screws  from the back of the device using the Phillips #0 Screwdriver. Remove the four 14 mm screws  from the back of the device using the Phillips #0 Screwdriver.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force. Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench. The nut uses a left-handed thread.
    • Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
    • The nut uses a left-handed thread.
  5. Grasp the fan blade firmly and pull upward to remove it from the center column of the fan. The slots on the fan blades and center column need to be aligned for reassembly.
    • Grasp the fan blade firmly and pull upward to remove it from the center column of the fan.
    • The slots on the fan blades and center column need to be aligned for reassembly.
  6. Remove the four 12.7mm screws using the Phillips #0 Screwdriver. Once the screws are removed, lift the motor off its base.
    • Remove the four 12.7mm screws using the Phillips #0 Screwdriver.
    • Once the screws are removed, lift the motor off its base.
  7. Remove the wire connectors from the black, brown, red, blue, white, grey, and green wires. To do this, grip each wire with your hand and use the pliers to de-crimp the heads of each wire connector by applying pressure to the wider ends of the connector until it falls free. While reassembling, apply pressure to the more narrow ends of the wire connectors to re-crimp them onto the wires.
    • Remove the wire connectors from the black, brown, red, blue, white, grey, and green wires. To do this, grip each wire with your hand and use the pliers to de-crimp the heads of each wire connector by applying pressure to the wider ends of the connector until it falls free.
    • While reassembling, apply pressure to the more narrow ends of the wire connectors to re-crimp them onto the wires.
まとめ
2 の人々がこのガイドを完成させました。
Armando Jacob Espinoza
メンバー登録日: 2014年10月14日
483 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 10-40, Amido Fall 2014 Cal Poly, Team 10-40, Amido Fall 2014人のメンバー
CPSU-AMIDO-F14S10G40
3 メンバー
7のガイドは作成済み
Where do you purchase the replacement fan motors from?
mattb - 返信
Do you know where I can find the fan motor replacement?
Dave Smith - 返信
統計データを表示:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 27
今までの合計 4,254
