はじめに
After removing the outer casing, replacing the fan blades is quick and easy! You would want to use this guide to replace the broken part or clean dirty blades.
必要な工具と部品
Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
もう少しです!
終わりに
