メインコンテンツにスキップ
Honda Fit Reset Oil Life Indicator Replacement
必要な工具と部品
    • Turn the key in the ignition to the run position (right before the start position)
    • Press the SELECT/RESET knob repeatedly until the engine oil life indicator is displayed.
    • Press and hold the SELECT/RESET knob for more than 10 seconds. The engine oil life indicator and the maintenance code(s) will blink.
    • Press and hold the SELECT/RESET knob for more than 5 seconds. The maintenance items code(s) will disappear, and the engine oil life will reset to 100%.
    • Turn the key in the ignition to the off position, and then start the engine to verify the indicator has been reset.
終わりに
You did it!
19 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Jasen Friedle
メンバー登録日: 08/25/14
3,821 ポイント
3のガイドは作成済み
5 件のコメント
Great. I did it—and I’m a girl!!
pthompso99 - 返信
Excellent! Glad to hear it.
Jasen Friedle - 返信
in my case i followed the step through. 100% oil life was achieved but when i turn the ignition off and turn it back on to verify, it goes back to 15%
Esosa Aghimien - 返信
And how can I start the car that it won't start
sbukataake - 返信
Have you tried changing your blinker fluid?
neegnorg -
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 112
過去 30 日: 472
今までの合計 76,573
