メインコンテンツにスキップ
Honda FC600 Tiller Throttle Lever Replacement
必要な工具と部品
  1. Honda FC600 Tiller Throttle Lever Replacement, Remove the Spark Plug Cap: 手順 1、 3の画像 1 Honda FC600 Tiller Throttle Lever Replacement, Remove the Spark Plug Cap: 手順 1、 3の画像 2 Honda FC600 Tiller Throttle Lever Replacement, Remove the Spark Plug Cap: 手順 1、 3の画像 3
    • Before you begin, it's important that you completely cut power to the tiller by disconnecting the spark plug. This will prevent the engine from accidentally starting up while you're working on the tiller.
    • Grab the spark plug cap and pull it straight out to disconnect the spark plug from the engine.
  2. Honda FC600 Tiller Throttle Lever Replacement, Preparation: 手順 2、 2の画像 1 Honda FC600 Tiller Throttle Lever Replacement, Preparation: 手順 2、 2の画像 2
    • Push the throttle lever all the way down.
  3. Honda FC600 Tiller Throttle Lever Replacement, Remove the Throttle Lever: 手順 3、 1の画像 1
    • Remove the 23 mm-long Phillips #2 screw securing the throttle lever to the handlebar.
    • This screw is accompanied by a square nut. Be sure to retain it for reassembly.
  4. Honda FC600 Tiller Throttle Lever Replacement, Remove the Small Throttle Cable Clip: 手順 4、 2の画像 1 Honda FC600 Tiller Throttle Lever Replacement, Remove the Small Throttle Cable Clip: 手順 4、 2の画像 2
    • Use a pair of needle-nose pliers to remove the small clip attached to the throttle cable.
  5. Honda FC600 Tiller Throttle Lever Replacement, Remove the Throttle Cable: 手順 5、 2の画像 1 Honda FC600 Tiller Throttle Lever Replacement, Remove the Throttle Cable: 手順 5、 2の画像 2
    • Grab the open end of the throttle cable and pull it out of the throttle lever to free it from its recess.
  6. Honda FC600 Tiller Throttle Lever Replacement: 手順 6、 3の画像 1 Honda FC600 Tiller Throttle Lever Replacement: 手順 6、 3の画像 2 Honda FC600 Tiller Throttle Lever Replacement: 手順 6、 3の画像 3
    • Continue to lift the throttle cable out of the throttle lever, making sure it clears the openings in the recess.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Craig Lloyd
メンバー登録日: 02/10/16
35,423 ポイント
82のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 18
今までの合計 787
