メインコンテンツにスキップ
Honda FC600 Tiller Throttle Cable Replacement
必要な工具と部品
  1. Honda FC600 Tiller Throttle Cable Replacement, Remove the Spark Plug Cap: 手順 1、 3の画像 1 Honda FC600 Tiller Throttle Cable Replacement, Remove the Spark Plug Cap: 手順 1、 3の画像 2 Honda FC600 Tiller Throttle Cable Replacement, Remove the Spark Plug Cap: 手順 1、 3の画像 3
    • Before you begin, it's important that you completely cut power to the tiller by disconnecting the spark plug. This will prevent the engine from accidentally starting up while you're working on the tiller.
    • Grab the spark plug cap and pull it straight out to disconnect the spark plug from the engine.
  2. Honda FC600 Tiller Throttle Cable Replacement, Preparation: 手順 2、 2の画像 1 Honda FC600 Tiller Throttle Cable Replacement, Preparation: 手順 2、 2の画像 2
    • Push the throttle lever all the way down.
  3. Honda FC600 Tiller Throttle Cable Replacement, Remove the Throttle Lever: 手順 3、 1の画像 1
    • Remove the 23 mm-long Phillips #2 screw securing the throttle lever to the handlebar.
    • This screw is accompanied by a square nut. Be sure to retain it for reassembly.
  4. Honda FC600 Tiller Throttle Cable Replacement, Remove the Small Throttle Cable Clip: 手順 4、 2の画像 1 Honda FC600 Tiller Throttle Cable Replacement, Remove the Small Throttle Cable Clip: 手順 4、 2の画像 2
    • Use a pair of needle-nose pliers to remove the small clip attached to the throttle cable.
  5. Honda FC600 Tiller Throttle Cable Replacement, Remove the Throttle Cable: 手順 5、 2の画像 1 Honda FC600 Tiller Throttle Cable Replacement, Remove the Throttle Cable: 手順 5、 2の画像 2
    • Grab the open end of the throttle cable and pull it out of the throttle lever to free it from its recess.
  6. Honda FC600 Tiller Throttle Cable Replacement: 手順 6、 3の画像 1 Honda FC600 Tiller Throttle Cable Replacement: 手順 6、 3の画像 2 Honda FC600 Tiller Throttle Cable Replacement: 手順 6、 3の画像 3
    • Continue to lift the throttle cable out of the throttle lever, making sure it clears the openings in the recess.
  7. Honda FC600 Tiller Throttle Cable Replacement, Remove the Air Filter Cover: 手順 7、 1の画像 1
    • Use your fingers to unscrew and remove the wing nut securing the air filter cover to the air filter elbow.
  8. Honda FC600 Tiller Throttle Cable Replacement: 手順 8、 2の画像 1 Honda FC600 Tiller Throttle Cable Replacement: 手順 8、 2の画像 2
    • Lift up and remove the air filter cover to reveal the air filter.
    • The air filter cover will still be attached to the tiller by a flexible hose. You can push the cover to the side while you continue to work on the tiller, or follow the next two steps to completely remove the cover.
  9. Honda FC600 Tiller Throttle Cable Replacement, Detach the Air Filter Cover: 手順 9、 2の画像 1 Honda FC600 Tiller Throttle Cable Replacement, Detach the Air Filter Cover: 手順 9、 2の画像 2
    • The next two steps are optional, but they will make it easier to work on the tiller from here on out.
    • Squeeze the metal clip on the inside of the air filter cover and remove it.
  10. Honda FC600 Tiller Throttle Cable Replacement: 手順 10、 2の画像 1 Honda FC600 Tiller Throttle Cable Replacement: 手順 10、 2の画像 2
    • Hold onto the air filter hose and pull on the air filter cover to remove it.
  11. Honda FC600 Tiller Throttle Cable Replacement, Remove the Air Filter: 手順 11、 1の画像 1
    • Use your fingers to unscrew and remove the wing nut securing the air filter to the air filter elbow.
  12. Honda FC600 Tiller Throttle Cable Replacement: 手順 12、 2の画像 1 Honda FC600 Tiller Throttle Cable Replacement: 手順 12、 2の画像 2
    • Wear gloves or use a rag during this step, as the air filter is coated with oil.
    • Lift the air filter straight up off the elbow, making sure it clears the threaded rod.
  13. Honda FC600 Tiller Throttle Cable Replacement, Remove the Air Filter Elbow: 手順 13、 1の画像 1
    • Use a 10 mm socket and socket wrench to remove the 25.5 mm-long bolt securing the air filter elbow to the tiller.
  14. Honda FC600 Tiller Throttle Cable Replacement: 手順 14、 1の画像 1
    • Use a 10 mm socket and socket wrench to remove the two nuts securing the air filter elbow to the carburetor's threaded rods.
  15. Honda FC600 Tiller Throttle Cable Replacement: 手順 15、 3の画像 1 Honda FC600 Tiller Throttle Cable Replacement: 手順 15、 3の画像 2 Honda FC600 Tiller Throttle Cable Replacement: 手順 15、 3の画像 3
    • Use a pair of snap ring pliers to loosen the spring hose clamp on the breather tube, pulling it out 2-3 cm so it's not clamping onto the end of the tube.
  16. Honda FC600 Tiller Throttle Cable Replacement: 手順 16、 2の画像 1 Honda FC600 Tiller Throttle Cable Replacement: 手順 16、 2の画像 2
    • Pull the air filter elbow straight off, making sure it clears the carburetor's threaded rods.
    • As you remove the elbow, you may need to use your other hand to remove the breather tube from the engine's valve cover.
  17. Honda FC600 Tiller Throttle Cable Replacement, Throttle Cable: 手順 17、 3の画像 1 Honda FC600 Tiller Throttle Cable Replacement, Throttle Cable: 手順 17、 3の画像 2 Honda FC600 Tiller Throttle Cable Replacement, Throttle Cable: 手順 17、 3の画像 3
    • Insert a flathead screwdriver in between the release tab and the tip of the cable tie securing the throttle cable to the handlebar.
    • Twist the screwdriver to separate the release tab and loosen the cable tie.
    • Repeat this step for the remaining cable ties.
  18. Honda FC600 Tiller Throttle Cable Replacement: 手順 18、 3の画像 1 Honda FC600 Tiller Throttle Cable Replacement: 手順 18、 3の画像 2 Honda FC600 Tiller Throttle Cable Replacement: 手順 18、 3の画像 3
    • Pull the throttle cable out of the cable holder underneath the handle column.
  19. Honda FC600 Tiller Throttle Cable Replacement: 手順 19、 3の画像 1 Honda FC600 Tiller Throttle Cable Replacement: 手順 19、 3の画像 2 Honda FC600 Tiller Throttle Cable Replacement: 手順 19、 3の画像 3
    • Use a pair of needle nose pliers to bend the metal clip at the bottom of the handle column out and upward.
  20. Honda FC600 Tiller Throttle Cable Replacement: 手順 20、 2の画像 1 Honda FC600 Tiller Throttle Cable Replacement: 手順 20、 2の画像 2
    • Use a pair of needle nose pliers to bend the last section of the metal clip outward to release the throttle cable.
  21. Honda FC600 Tiller Throttle Cable Replacement: 手順 21、 3の画像 1 Honda FC600 Tiller Throttle Cable Replacement: 手順 21、 3の画像 2 Honda FC600 Tiller Throttle Cable Replacement: 手順 21、 3の画像 3
    • Grab the end of the throttle cable with your fingers and push the cable inwards so that it lines up with the small cutout on the control lever.
    • Lift the throttle cable straight up to free it from the control lever.
  22. Honda FC600 Tiller Throttle Cable Replacement: 手順 22、 3の画像 1 Honda FC600 Tiller Throttle Cable Replacement: 手順 22、 3の画像 2 Honda FC600 Tiller Throttle Cable Replacement: 手順 22、 3の画像 3
    • Grab onto the end of the throttle cable housing and pull it out of its holder on the control lever.
    • Lift the throttle cable straight up to completely remove it from the control lever.
  23. Honda FC600 Tiller Throttle Cable Replacement: 手順 23、 3の画像 1 Honda FC600 Tiller Throttle Cable Replacement: 手順 23、 3の画像 2 Honda FC600 Tiller Throttle Cable Replacement: 手順 23、 3の画像 3
    • Pull the throttle cable all the way out, fishing it through the clips, cable ties, and guides.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Craig Lloyd
メンバー登録日: 02/10/16
35,423 ポイント
82のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 40
今までの合計 2,156
