はじめに
Follow this guide to replace a worn or damaged carburetor on the Honda FC600 tiller.
必要な工具と部品
Grab the spark plug cap and pull it straight out to disconnect the spark plug from the engine.
Use your fingers to unscrew and remove the wing nut securing the air filter cover to the air filter elbow.
Squeeze the metal clip on the inside of the air filter cover and remove it.
Use your fingers to unscrew and remove the wing nut securing the air filter to the air filter elbow.
Use a 10 mm socket and socket wrench to remove the 25.5 mm-long bolt securing the air filter elbow to the tiller.
Pull the carburetor spacer straight off, making sure it clears the threaded rods.
Press and hold down the fuel valve's safety lock button.
Begin to turn the fuel valve knob counter-clockwise, continuing to hold down the safety lock button until the knob clears the button.
Use a pair of needle nose pliers to squeeze and loosen the spring hose clamp on the fuel supply hose.
Move the clamp up 2-3 cm so it's not clamping down onto the end of the tube.
Pull the carburetor halfway out, but do not completely remove it yet.
ある他の人がこのガイドを完成しました。
