はじめに
This guide demonstrates how to remove or replace the cyclo converter panel in your Honda EB3000CK2A 3000 Watt Generator.
必要な工具と部品
Use a 10 mm socket to remove the nut securing the top of the cyclo converter cover.
Use a 10 mm socket to remove the bolt securing the bottom of the cyclo converter cover.
Pull the cyclo converter panel off of its posts on the generator body so the screw terminals are easily accessible.
ある他の人がこのガイドを完成しました。
