はじめに
If the you are having problems turning on the shear or the operating switch seems too loose, this guide might be useful for replacing the part.
  1. Locate and remove the six 1.5 cm screws marked on the picture from the plastic casing with a Phillips head screwdriver.
    • Locate and remove the six 1.5 cm screws marked on the picture from the plastic casing with a Phillips head screwdriver.
  2. Remove face plate by lifting it away from the body of the mechanism, to expose inner mechanisms.
    • Remove face plate by lifting it away from the body of the mechanism, to expose inner mechanisms.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Locate and remove the operating switch by pulling it away from the body of device. Locate and remove the operating switch by pulling it away from the body of device.
    • Locate and remove the operating switch by pulling it away from the body of device.
  5. If Spring seems deformed or broken then pull spring away from switch and replace similarly.
    • If Spring seems deformed or broken then pull spring away from switch and replace similarly.
    • When reinserting spring be careful the wires don't get caught in the spring.
まとめ
Adam soto
メンバー登録日: 2015年01月30日
301 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 17-5, Watkins Winter 2015 USF Tampa, Team 17-5, Watkins Winter 2015人のメンバー
USFT-WATKINS-W15S17G5
3 メンバー
4のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 107
